Reeds - are they really much better than oem
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
I found some relatively cheap carbontech reeds. Thinking about upgrading my inatke (I already have an angled R&D mani spacer). The manufacturer states that they will give a very noticeable boost in low do mid and + 2/3 hp. I would like to hear your opinion about these. Are these much worse than e.g V-force II or III's? I also know that tension makes a difference. I need a set for freestyle.
Thank you all!
Andrew
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Here's the reeds we recommend for replacing stock petals when using stock 62T cages...
96-08 Super-Jet 701 202LT +3 HP In The Midrange
When using these I also use the Boyesen reed stuffers as well.
REED VALVE STUFFERS
Part #RS-02
Polish jet pilot
Warsaw, Poland
Will these be ok if I port the cylinder? And I see these are the low tension ones...
Thank you Supertune. I imght have a Clent for you guys soon for an engine package - range above 800cc - 62T cases, with possibly stock crank.
Andrew
