http://www.x-h2o.com/threads/22890 Check out the tech section,LOTS of good info there.
The Rad flywheel is cool. I found the timing a little retarded on mine, (at the stock setting...magnet strength and location?).
If your serious about performance, find TDC, setup a makeshift pointer, and check things out with a timing light.
I don't think it will work with a Advent ignition module.
