joe b
depth tester
- northfield, nj
Anyone know if a round nose pole will fit a square??
Yes it will. Contact legdragpete, he has the conversion bracket(I think its 140 bucks).
or you can make your own if you have access to that kind of stuff, or know how to weld.
...but yeah, its possible.:biggthumpup:
or do like I did, just drill new holes, and use the Roundnose Bracket too.
I would ad a shim under it so it sits closer to level though.
I had to grind my pole a bit to get it to go up high enough.
a simple piece of wood, glassed over would have changed that.
An FX1 steering cable.
