i think its just cut and fit... heat, cut, and fit..
i started at the top to bottom then tightened up the front solid and worked it to the back..
jeff might have some tips, good luck:biggthumpup:
go to home depot...its a contact cement called welwood
brush it on both sides let dry... two coats if u want and rubber mallet it on (mallet helps get the air bubbles out)
time consuming crap but take it slow and watch what u cut b.c u can only cut once:smile:
