The pick up coil is mounted inside your flywheel cover. Once you take the cover off, remove to two screws that hold that little black thingy with two wires coming out of it. Then mount the timing plate that came in the kit where the pick up coil was. Then mount the coil to the plate. You will have to file down the front corner of the coil to get clearance with the flywheel cover. It's a pofc. Hope this helps
