CarFanatic
Fiberglassing Newb
- Cincinnati, OH
ok, how do I get this out, I want to seal the holes in the hull and install my bilge pump. IS it just those 2 bolts, on on each side?
Are you having a tough time getting those two bolts out? If you've ever been within 100 miles of salt, that will be a problem area. Easiest thing to do is pull the 4 through-hull bolts holding the brackets to the firewall.
Search for "electrical box," or "e-box." There are a couple of recent threads talking about this very problem.
