Other Quick engine swap question?
It should be doable if it's a non-R hull. Motor mounts get bolted to a different spot, midshaft length is different, and the exhaust hose diameter is different. Water box may br different, too.
I have done that swap before. Or maybe it was a 701 into an 1100 hull. The principle is the same.
