Question for 1100/1200 blaster conversion folks
What did you do or use to secure the water box in the rear section? Rubber, foam, etc?
I need to do something to secure this water box so that it doesn't wear into the hull from vibration and movement.
Texas
From what I've read, most wrap the water box with hydroturf, then spray foam around it in the hull to hold it in place. I haven't done this swap YET, but really thinking about it. Where do you normally ride? I'm in n.e. Houston and sometimes go to Livingston.
For the past couple years I have ridden at a private lake at a three palms extreme sports park but we recently lost that lake as it is being turned into a cable park for wake boarding. I just registered my boat for the first time in years. I have been out to lake Conroe once since.
