steve-uk
Manners cost nothing
- Barrie - ontario
ok so i read the "how to shim thread" in the faq section
i just bolted up my pump and the drive shaft is sitting up towards the right of the opening (as you look at it from the pole)
so its clear your not supposed to shim the front end of the pump (has the dowels in so wouldnt be possible)
but if i shim the rear two this will have the affect of raising the shaft even further
photo attached, angle of phot isnt great, but its def not near the centre
advise appreciated
advise appreciated
