Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
SO I'm working on this ski with a bunch of Protec parts:
61x
Protec head 150psi
Protec dry pipe
Protac dual intake
Dual A/M 38mm carbs
Jetting is:
70L
1.5 turns out on the lows
115g
2.0mm n/s
132.5H
1.25 turns out on the high
Theres a low end stumble which I'm going to fix with a 75 low jet.
The ski actually runs great from low/mid to high throttle. It will scream straight across the lake and the plugs look good. The bottom end stumble is slight which I know a 75L will fix.
The big problem is; when you go 'crazy' with the ski. Take a few nose stabs, spin outs, pop-ups, or fall off hard - and the ski stalls out. It barely starts and when it does sounds like 1 cyl. I pulled it ashore and pulled the plugs which look OK, but it still runs like crapity crap. If you ignore and just keep blipping the throttle for about a minute - the ski "clears up" and starts to rip perfect again - that is only until you go crazy and get the boat rocking again.
My thought was perhaps a water intrusion?
My friend thought the needle/seats may be hanging up?
Thoughts?
61x
Protec head 150psi
Protec dry pipe
Protac dual intake
Dual A/M 38mm carbs
Jetting is:
70L
115g
2.0mm n/s
132.5H
Thoughts?
