Protec Mach 1 help
steve-uk
Manners cost nothing
Barrie - ontario
i have a Protec Mach 1 pipe im trying to fit to my FX1
just trying to work out the Piping
my guess is the feed fronm the pump goes to the bottom of the manifold, the feed to the top of the manifold is the one that goes to the head
now heres my issue, the water pipe i have coming of the head had a t which then goes to the pisser...
i though the pisser came off the fitting on the exhaust chamber...
anyone got a manual they can email me?
haggis
its raining again!
Mine runs the pump to bottom of manifold.
the head to the inside water fitting on exhaust
the outside water fitting down to stinger with a t which runs to pisser
second water fitting on head to 2nd pisser.
Im not sure what the second fitting on the manifold is for as mine has been plugged from new, could be dual cooling?
Hope this helps
haggis
its raining again!
Not quite, do you have 2 welded spiggots on the head pipe?
ifso then the one you can see in the pic runs directly down to the stinger. Then on the opposite side of head pipe that one runs to the head.
Again Im not sure why there is 2 water fittings on the manifold as mine doesnt use the top one.
steve-uk
Barrie - ontario
actually.. when you say spigot if your taking about the one thats on the bottom of the head pipe.. there is another on the back.. but they are not through holes
haggis
its raining again!
Nearly, Pump to bottom manifold,
Spiggot ontop of headpipe down to stinger on chamber
Spiggot on bottom of headpipe to cylinder head.
You can the put a t in between the stinger and headpipe to run to pisser
The only one I dont use is the water fitting ontop of the manifold.
tor*p*do
Squarenose FTW
NW NC
it looks to me like that exhaust maifold is set up for dual cooling
both those brass nipples are inlets from the pump
tapped for a second cooling line
water come OUT of the head to another nipple
is it on the backside in your photo?
steve-uk
Barrie - ontario
makes sense.. im not running dual cooling so ill block the top one off
thanks guys!
