Prop question PICTURE
Hello I currently running a skat 9/17 with my modded 701.
I just purchased a used hull that came with a bumch of stuff includings a whole jet pump.
Question: I read the numbers on the prop but dont under stand them.
Solas 145-18 y6-sc-1
What prop is this and how will it diff from what I am running.
I want to swap them out to feel this diff but I am a little puzzled on how to get this prop off. It isnt like my Skat were you put a wrench on the prop and spin it off???
Thanks
Dan
dfw
The Solas YB-SC-I is usually more load than the Skat 9-17, it could hurt accelleration. You need to remove the cone seal and use a Solas tool to engage the prop. Why not install the whole pump as it is?
Shonuff
I've got the glow
Memphis
It's a 14.5/18 and will need a lot of engine to pull it. It will have nice top end, though. You'll need an impeller tool to remove it once you get the rubber boot off.
cracking myself up
