- Dalhart, TX
Hey guys, just bought a 97 superjet about 3 weeks ago and its already giving me trouble. Its got a 701, riva dry pipe, msd total loss, and mikunis (46 maybe?). Anyways I took it out to the lake a couple weeks ago and it ran great. good power band and throttle response. Then i took it to the ocean and didnt make it over the first set of waves before it died. So i brought it back up to shore and it started fine. Tested the compression and its about 130-135 per cylinder. Flushed it when i got home and put it away. This morning I checked the spark plugs, they were fouled so I cleaned them up, put them back in and started it up. As soon as I started it, it would rev really high and stay like that, almost as if I was pulling the throttle in but I wasnt touching it. I wasnt running water through it when I started it. So this leads to my question: is it something to do with the carbs and throttle? Or is there a hole in my case somewhere thats sucking in air? It seems the cases werent sealed great (just with silicone). I dont know much about engines and any help would be greatly appreciated on how to fix the high rev. Also if theres anyone in the central coast area who wouldnt mind taking a look at it to try to diagnose it/ fix it I would greatly appreciate it.
Thanks
Anthony
Thanks
Anthony
