sharkcus
Breakin' the atmosphere.
- Strongsville, OH
I'm attaching a picture of how I have it hooked up.
I do not use the electronic water injection, so that port is blocked off. I have a RIVA head, one of the two water outlets has a (stripped) brass plug in it so if I want to use it, I have to take the head off and remove it. (no big deal).
I took it to the lake yesterday and warmed it up. If I drop water on the head, it sizzles away within 5 seconds. Same with the pipe. When I got back from my test ride, my waterbox was VERY VERY hot, but the line from my head to pipe popped off so that doesn't really mean anything. I noticed that every single port on this pipe (pro-tec mach II) has a restrictor in it. I can hold my hand under the pisser (coming off the head) for about 3 seconds when it's running.
So my questions are, is there a better way to plumb this? If I open up the other water output port on my head, should I run it to a pisser or maybe the stinger and run the headpipe water exit to a pisser?
Is my head/pipe supposed to be that hot?
Here is the original
Here is how mine is setup (only red lines are hooked up, ignore the lines in the diagram)
