Pro-tec Blaster I pipe, any good?
I have a friend that has one of these same pipes on his SuperJet. Its been pretty reliable.
As for performance gains between this and the red Riva pipe, I beleive they will be almost identical.
From an installation point of view, the red Riva pipe is fairly difficult to install. Its easier to unbolt the whole motor, turn it sideways then bolt everything on. If installation isn't an issue I would rather have the red Riva pipe. The sucker is practically bullet-proof.
* Note that the Riva red pipe has a tendency to blow through its manifold-to-headpipe gasket if the upper head mount gets loose.
