mk1
PUDDLE - BLASTER
Fitting a primer kit to my fx1 with a stock 44mm carb , where do I connect the pipes up to..??
Thanks for the advice , much appreciated..You need to install a 1/4-1/8-1/4 tee in your fuel line, feed to the primer, and remove your choke butterfly and shaft and replace with a block off plug and nipple plug. The outlet of your primer then goes to the nipple on the carb. PM if you need any of these parts or a whole kit, we have them in stock.
Hi , I am fitting a primer kit to my fx1 with a 46mm mikuni carb. I need a block off plug and a nipple plug for same. How much would it cost to have these posted to Ireland. I also need 2 aluminium side squirters , 10 foot of 3/8 inch transluscent blue water pipe , and a Y piece water connecter. If you stock these also please quote me for all of it. Thanks...You need to install a 1/4-1/8-1/4 tee in your fuel line, feed to the primer, and remove your choke butterfly and shaft and replace with a block off plug and nipple plug. The outlet of your primer then goes to the nipple on the carb. PM if you need any of these parts or a whole kit, we have them in stock.
