- CT
Put a 44mm sbn Carb on my ski with a pipe also. Did a few run with it and blew a coolant line. Ski died because the air filter was soaked. Dried everything and did a coupe more runs and the same thing happened. Dried everything and got it running again. This made me think if I sub the ski or even tip over the ski its going to die if the filter gets wet, right. Should I have a sock/pre filter on the filter? It came with a k&n filter. Any thoughts or recommendations? Also, what a huge diffence from the stock 28mm and stock pipe. WOW!!!!!
