Peter123
C-Note
- Houston, TX
I have a SJ 701 with single carb.
When I start it up and ride it, great no problems.
However, after a few spills, it will start to bog so bad that there's not even enough power for me to get up and it sounds like its running on one cylinder (coming from someone still rather ignorant - so I can't say for sure that it's just running on one). If I let it drag me around for a while or if I take it to shore for a little while and leave the hood off, it's right back to normal.
The hood seal isn't that great, so I'm getting water in it, but not that much. But there is enough so that when I pull the hood, a lot of steam comes out. I would imagine that if the carb is pulling in a lot of steam, it may cause the problem.
Any suggestions? Does the steam sound like a possiblity or do you think something electronic may be getting damp that shouldn't?
