- Delray Beach, FL
Where did you run the cables back in the hull then?http://www.x-h2o.com/threads/103076-The-What-is-your-biggest-Rookie-move-on-a-build&highlight
I made that mistake and it cost me a new cable. The first post in that thread shows my cable and what happened from running it around the neck of the waterbox.
Cool. Do I run it behind the tank and battery? Does it tie to the tank strap?Split spare hose n zip tie around rub areas.
