Poked a small hole in waterbox rubber pipe.
How can i fix a small puncture hole in my stock superjet waterbox's rubber pipe which is in between engine and waterbox.
Do i need to buy a full replacement?
I was thinking about using some liquid gasket to fill it, since that can withstand heat and then wrap it with some silicon wrap i found on amazon for like 11$.
Does that sound okay? Do i need anything fancy, or will there be some sort of pressure i need to worry about it.
Stockton
Replace it!
In a pinch if I was broke down on a trip, I’d cut an aluminum can and 5200 silicon it over the hole and put a hose clamp around it...
Then replace it
Thanks. And can you explain mechanically why? Do those have a ton of air pressure and it will pop my seal right off?
Now i gotta figure out the best and cheapest way to find that part.
Stockton
Heat, oil and gas plus back pressure... but if wasn’t to try a repair ism sure you could get it to work..
Do you have room to Cut the hose in half and slide In A second of tube and hose clamp it ?
I have that on my outlet hose from water box to bulk head and it works fine
its got two puncture holes. From my lack of planning on my Tubbie installation =[
So, ill just stick to looking for a replacement. I found one on ebay for 70$. cant beat that. Although it looks different than the one i have slightly.
The guy before me put a 2001 701 62T superjet into my 94 square nose body. So i need to look for a 2001 superjet waterbox hose, and not a 94. right?
I think these look like squarenose waterbox.
