Super Jet plug wire/boot ?
BruceSki
Formerly Motoman25
Long Island
Look inside the boot. If it has a threaded screw inside it where the wire goes you are fine. Spray some lube on the end of the cut back wire and twist the boot back on it.
You should be fine. Most NGK boots I've seen are the twist off type.
