I ran it for a a good solid 45 min with no sputters or bogs.
At the end of the freeride I would like to pull my flywheel and send it back with you to have it lightened. By any chance will you have the tools with you that I will need to pull th flywheel?
Thanks:biggthumpup:
I would imagine Paul will have the puller for the flywheel. Last time he brought a whole trailer of tools and parts. If not, I live about 30 minutes away and can bring them Sunday if you guys want to pull flywheels or Paul gets to busy with other stuff. All you need is a screw driver (to remove gas tank), a 10mm socket (to remove flywheel cover), a 17mm wrench, and the puller. Just look for a white work van, it will most likely be stuck on the beach.
