Christian_83
Xscream
- Denmark
So the first batch of Pitch Components trim arrived:
The details:
Full billet and anodised trim system, no welded parts.
Fully tuneable with interchangeable rings in both exit nozzle and steering nozzle.
Exit nozzle from 88-95mm
Steering nozzle: 94-99mm
Trim is fitted with 4" silicone coupler for rubber flowguard.
Trim comes with "true 30deg trim" out of the box, with custom made Pitch trim lever (no cheap bike lever here)
1295 usd
So whats included in the kit:
Exit nozzle with 1 ring
Trimring with rubber coupler
Steering nozzle with 1 ring
Trim cable
Trim lever
Return spring.
Bolts and bushings.
Check them out at https://www.instagram.com/pitchcomponents/
The details:
1295 usd
Trim cable
Trim lever
Return spring.
Bolts and bushings.
