Piston squish 701
Well after the longest headache and something I put my all into fall apart I finally and started getting stuff together. If you know I bought a xft fly-x hull with “everything to put it together”. Well I got it for $5300 in total and that was a big purchase for a 18 year old kid that works his tail off to make it happen. After fighting for a b pipe and a few small things I had about $6300 in the ski. That was with the ski running and almost flipping! I got to ride it for about 30 minutes and the hull started to fall apart. I got home pulled the motor and flipped the ski around to find a huge issue with the hull I had no clue about. I then started looking in the motor and saw a cracked piston right on the exhaust side. I got the hull at a glass guy atm getting it all fixxed up. I just got the motor back together after a headache. I am now checking piston squish and it looks it be at about .31 thousands which is to tight. I had a ada head on it now with 35cc domes. My question is if I am running the stock .020 base gasket and I need my squish to be about .50 thousand what thickness does my base gasket meed
To be? Thank you guys!
