nikad58
1974 YZ 701
- 200 miles west of Havasu !
the ad..
Description
Yamaha Waverunner 700 Engine Complete 701 w/ Electronics
Engine has low hours.Was run hot.It is not siezed but has very low compression in one cylinder.It will need at least the top end rebuilt.
It comes to you complete,including starter,all electronics,carb(which needs rebuilding.I will ship this but it will be expensive as it is very heavy.Sold as is.
(i talked to him on the phone and this motor was running when they pulled it out of the ski... lol ya right.. like a steam engine.. clang,pooof,fizzzzit)
I filed a claim and lost..
errrrrrrr ( ME)
I am appealing this because I still feel it wasn't decribed correctly
or
he was selling a junk motor..
I bought this motor EXPECTING to rebuild it or at the minimun have a REBUILDABLE CORE and there is nothing to rebuild other than the carburator..
This is a 2 stroke engine and the crank came apart from running it
out of oil.. the owner stated is was ran out of water "hot" which would cause the
need for a new bore and the pistons to be repalced not much else other than
gaskets/seals..
The crank came apart on this engine (from being run with no oil) and
the pieces of the crankshaft destroyed the head (unrebuildable) ,
reed cages (unrebuilable), cracked the cylinders (unrebuilable), ruined the
pistons (normal replacment on a rebuild),
ground away at the engine block so much that cracked it, its un useable
(unrebuilable)..
if i was to try and rebuild it i couldnt/cant !! I would have to replace (to rebuild this engine) the head,cylinders,crankshaft,engine block,pistons,reed cages.. this engine
i bought cant even be used as a core for a exchange for a rebuilt engine from
SBT ( a major rebuilder of PWC engines I checked ).. IT IS NOT A
REBUILDABLE ENGINE.. the estimate i got at B&B yamaha here in
victorville calif (that you requested cost me $80.00 for 1 hour labor for a mechanic to check it
out) the parts alone ran over $2500.00
This just isnt right at all.. no is no way he could have done a
compresion check on this engine without having it lock up from parts
moving around inside this engine.. He told me it was running on the phone..
If need be I will get a statement from Yamaha proving it could not
run at all !!
This is too much money for a boat anchor
Thank you.. Butch Musick
(them )
In order to continue with the investigation of your claim, we must
request
documentation to support your claim that the item is damaged or
significantly not as described. Please obtain a document (such as an
estimate or invoice) from an unbiased third-party, such as a dealer;
repair
shop, appraiser, or another individual or organization that is
qualified in
the area of the item in question (other than yourself), which details
the
extent of the damage or clearly explains how the item received
significantly differs from the item advertised. Please do not proceed
with
any repairs or alterations to the item, as doing so will limit PayPals
ability to successfully resolve your claim, and may result in the
cancellation of your dispute. If possible, the document should include
a
serial number and description of the item, and the dollar amount
required
to complete the repairs necessary to correct the damage. This document
must
be on letterhead that includes the name, address, and phone number of
the
individual, business, or organization so that PayPal may contact them
if
necessary.
The documents should be faxed to PayPal at (402) 537-5760 (please note
this
is a United States phone number, if you are faxing from outside the
United
States, you will generally need to dial 00 1 before the number). Please
include a cover sheet with your fax that includes the email address
registered on your PayPal account and the ID number of your claim
(PP-158-014-966) so we may attach the document to your claim as quickly
as
possible.
We must receive your fax within ten days from the date of this message
in
order to proceed with the investigation of your claim. If we do not
receive
your fax within ten days, your claim will be cancelled. Unfortunately,
we
are unable to grant extensions to this time period. Please note that
PayPal
is unable to reimburse you for any costs or fees that may be incurred
in
obtaining the requested documents. Any documents you provide may also
be
supplied to the seller in your dispute.
Thank you for your cooperation and patience. We apologize for any
inconvenience this request may cause. Please do not misconstrue
PayPals
request as suspicion that your claim is not valid. As we are an
internet-based business, we do not have the opportunity to review the
relevant items and evidence in question. Therefore, we must rely on the
documents described in our request to continue with the investigation
of
your claim.
Sincerely,
Dennis
Protection Services Department
PayPal, an eBay Company
I FAXED them a estimate.. OVER $2,500.00 IN PARTS ALONE..this engine was junk !! REALLY
they closed the case saying I knew I would have to rebuld it.. I appealed it.. telling them there is nothing to rebuild... came out the same way..
Apr. 22, 2006 PayPal Case closed
Apr. 22, 2006 PayPal Appeal denied
Apr. 22, 2006 PayPal Email sent to Buyer
Apr. 20, 2006 PayPal Case in Review
Apr. 20, 2006 Seller Decision appealed
Apr. 19, 2006 PayPal Case closed
Apr. 19, 2006 PayPal Claim denied
Apr. 19, 2006 PayPal Email sent to Buyer
Apr. 19, 2006 PayPal Email sent to Seller
Apr. 18, 2006 PayPal Case in Review
Apr. 18, 2006 PayPal Fax Received from Buyer
Apr. 18, 2006 PayPal Additional information requested
Apr. 18, 2006 PayPal Email sent to Buyer
Apr. 13, 2006 Seller Email send to Paypal
Apr. 13, 2006 PayPal Phone call with Seller
Apr. 12, 2006 PayPal Case in Review
Apr. 12, 2006 PayPal Email sent to Seller
Apr. 12, 2006 PayPal Email sent to Buyer
Apr. 12, 2006 Buyer Complaint case initiated
Description
errrrrrrr ( ME)
or
gaskets/seals..
(unrebuilable)..
run at all !!
(them )
request
repair
qualified in
the
with
a
required
must
the
if
necessary.
this
United
as
possible.
in
receive
we
PayPal
in
be
PayPals
of
your claim.
Sincerely,
Dennis
