Parts That B1 And Superjet share
junkyardj
┌∩┐(◣_◢)┌∩┐
you mean which can you use or whats common?
alot of parts can be used motor pump -driveshaft,mid shaft housing,most electrical can be used but wires are different lengths
munki63
Epoxy is my duct tape
Canada
Im thinking about getting a hull and i have a few electrical stuff from my 04 and some more from a 94, not enough too get it 100% but just so when im buying things im getting the right stuff
junkyardj
┌∩┐(◣_◢)┌∩┐
i pretty much bolted my sj motor right into my b1 hull i just needed different wires for the box.. the ski already had the pump and mounts so it went in pretty easy.. i was told the mounts are differnt.. i used a sn steering cable on my friends b1 at daytona and it worked too..
munki63
Canada
ok, thx so if that hull has the pump i can just bolt a 701 in and ride it
it sucks living in Canada only when you have too drive 17 hours too go pick up a dam toy!
customride0105
sterling va
start stop from the sj will work in the b1.
motor mounts are different. but fx1 motor mounts work in the b1
pumps are the same different shafts b1 is longer
intake grates are the same.
exhaust hose are different,
motor same and acc same,
