Part# for driveline side yamaha crank bearing?
Anybody Know the part number for a bearing that will replace the oem bearing?
I seem to remember that there was a commonly used bearing that was identical except for the alignment pin hole.
Or if anybody has a nice quiet stock one they'll sell me for cheap that would work to..
Thanks.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
goto a local bearing shop ( or GOOD auto parts store.)
and have them match it up.
there are a ZILLION variables on bearings, but Id bet they can get one thats close.
OEM part number is
93306-307U3-00
$56 at Riva
$42 at Ronayers.com
I still got 2 broke cranks. You've gotten a bearing from me before, you can get it again.
Kaveman
Born in USA(not Kenya)
Use caution when getting "replacement" bearings. Not all bearings have a high enough RPM rating. I would recommend going to a long-standing bearing business and talk to some old guy that was there when the business started...that's the guy that'll put you on the right one.
dfw
Its been a while but I think they are 6207C3 bearings, they must be a C3 or looser fit. You will have to (carefully) drill reliefs for the pins. I have seen these used with in overhauled cranks without problems. You may be able to find them surplus on ebay for next to nothing.
