paint
KR
www.krlines.com
Sorry I don't know what happened there. Anyways, I know their is probably a million threads on how to paint a ski. My hull looks terrible, and I need to paint it. I want to do it cheap. I am not the richest college student ever. Any thoughts on how to do all this. I would prefer someone tell me in step by step format. Thanks!
that was less than enlightening...:dunno:
do not wipe w/ acetone after sanding.... EVER
Acetone is way too heavy for that kind of use..
this is the process:
  1. clean surfaces
  2. sand w/ 80 grit w/ a DA sander
  3. clean w/ pre-paint cleaner
  4. fill and sand w/ 80, then 180 grit w/ a DA sander
  5. block (if needed)
  6. clean w/ pre-paint cleaner
  7. prime w/ high filler primer, apply guide coat
  8. wet sand w/ 400 grit, 600 grit or 180 on a DA sander
  9. clean w/ pre-paint cleaner
  10. apply sealer (wet on wet) let dry then wipe w/ cheese cloth
  11. apply color 2-3 coats till it's fully covered wipe w/ cheese cloth
  12. apply clear 2-3 coats till it's smooth and glossy
  13. wet sand w/ 2000-3000 grit, polish w/ heavy cut cleaner then light cut
  14. remove swirls w/ foam pad and swirl remover
ride it and break it and do it again....
KR
www.krlines.com
  1. clean surfaces
Hah that sounds pretty good to me. Couple questions though. What is a DA sander and what is cheese cloth?
DA sander:
url
tack cloth/cheese cloth/tack rag:
Crab
thanks darin...noswad!
Seattle
Sand
Prime
lightly wetsand with 220, wash and dry
3-4 light coats of Interlux, about 15 minutes apart (after flash)
Try not to get rolled on the beach.....
  1. clean surfaces
I should add that you only fill w/ filler and sand w/ 80 grit if needed...
like dents, and so on... the filler will stick to that better than a finer grit paper
KR
www.krlines.com
cool sounds good, I will post pics of my project ski, I am also installing footwells and new hydroturf molded diamond all around the ski. Another question though, how do the guys get decals on their skis? like red bull or a monster decal? do they put on the sticker and put clear coat over? How does all that workout?
Lucifer
Jet Junkie
Croydon PA
  1. clean surfaces
This is the RIGHT way to do it !! :arms:
