ORIGINAL WEIGHT DIFFERENCE SUPERJET HULL AND HULL FIBERGLASS Rickter
ATB
RICKTER XFS 1100CC
granada spain
hi.I would like to know what the difference in weight of an original hull and a hull Superjet jet rickter fiberglass.
thanks
ATB
RICKTER XFS 1100CC
granada spain
any persone give me one reponse???
i have weight superjet originnal---its 146,5 kg
give me please total weight rickter please===??
Im not sure if i am correct but i believe that the fiberglass one is 90lbs and carbon is 80 lbs.... For some reason i remember seeing that somewhere... Correct me if im wrong
Wow, I am surprised there isn't more weight difference between the two versions.
Thanks for posting those weights.
Those include the hood weights, right?
IceMan
Building a ski in Progress
Yes it includes the hood!!!
However; RRP has a Carbon/Kevlar version of the Rickter that weighs 31 kgs which is the lightest one they have!!
This version of the C/K Rickter is recommended for pro riders only!!
Aircraftsalz
Thrust built Dasa Power
Off site
My Carbon Rickter with Hood was 86lbs before I installed anything. (Thats Hood, Scupper, Footholds, turf, pole pad)
We weighted mine 3 wks ago 1/2 tank, heavy 14lb battery, & 1in water in the hull & it was 297lbs. So I would guess no fuel & no water & my 6lb battery 260-265lbs
Thats also XS1000 motor, Billet mag pump, etc.
The Rickter's ride lighter than the scale shows, wider & shorter make it feel so stable.
IceMan
Where are you getting these numbers? Mine and Aircraftsalz cams from a SCALE. His carbon Rickter is almost 20lbs lighter than my fiberglass one.
Aaron
Did you weigh the hulls on the same scale????
Did you weigh the hull with or without motor + pump???
Do you have the same setup as he does???
I got these numbers from Rick Roy :439:
Anyways you can contact RRP and verify the numbers I posted!!!
Aircraftsalz
Off site
My Carbon Rickter was weighted on a Certified shipping scale, I would say its right since I also weighted myself & it was right on.
Hull was 75lbs (Footholds, Scupper, Turf)
Hood was 11lbs (Hood & Pole Pad)
By no way are Rickters light ski's, but the ride is worth the weight IMO
As far as what a ski weights from the builders website, etc. most of those weights are BullSh*t.... Real deal weights are what I care about.
ATB
RICKTER XFS 1100CC
granada spain
thanks for the reponse.
i think i buy rickter fs2 in fiberglass.
but anypersona i say me i have not rrp fs2 white in stock.
