- California
I have a 1993 superjet with a 701. I am looking for opinions on what my jetting should be. Here is a breakdown of the engine. It was a 701 but has pistons that are 75 over. It has a DASA head running about 175 PSI on compression. It has a lightened flywheel. Porting was done but I don't know by who or the specs. Factory B pipe. Electronics were modified to increase rev limiter. The carburetor is currently a 46mm with a main 150, pilot 120, seat and needle 2.5, and an 80 gram spring. I have the low set at 2 turns out and the high at 1.5. When i am about half throttle and go to give it full throttle, it delays about 2 seconds and then kicks in.
any recommendations would be appreciated. I think i need to increase my pilot jet????
