i use these only $10 a pair have them on my sx-r and an x2 and a 550 all are 7/8 bars.... grips are 130mm long which is the same as most odi's but some odi's also come 90mm just measure and see how much room you have on your bars
My 06 SXR had a flat flange welded onto the bar ends to keep the grips from coming off. Not sure if Kawi was doing that on the older ones or not. If so, just chop them off with a hacksaw and the ODI's will slide right on.
