Novi 44 problem, will they work at 27psi popoff?
Crab
thanks darin...noswad!
Seattle
Help, just got it back together and it is pumping fuel but won't pull through the carbs. All I changed is downsizing the pilot and raise popoff.
#ZERO
Beach Bum
Florida - U.S.A.
You need to increase the size of your pilot jets when you raise the pop-off pressure.
The Novi 44s have a great main circuit but suffer from a lower then stock signal on the pilot circuit; so make the low speed jet a lot larger then you would normally run.
