Hi all,
New member here, although I have been lurking around the forums for some time. I bought a 1990 Superjet 650 last summer and now I'm hooked. Most of the time I can get my questions answered by searching, but this one has me a little stumped. I just pulled the ski out of storage a month ago and its been giving me starting problems on and off. First time I took it out for the year, it ran great even with the old gas (winterized and stabil added before storage). When I woke up the next day, I filled up with a fresh tank and it ran great for an hour or so. Went and ate lunch and came back to it not starting. I figured maybe the plugs fouled (I was running it hard though so they shouldn't have). So I ran into town got a new set and replaced them. It started back up and ran fine the rest of the day. The following morning I go to start it and it does the same thing and won't start even with another set of new plugs. I trailer it home and use an inline spark tester and find no spark. I went outside today and it started right up again. So I'm thinking its stator or CDI is going bad. So here's my questions:
1) Anyone ever have them go in and out like this before failing completely?
2)Right now its running, so if I measure resistance or voltage over the various coils, will it show that they are bad?
3)What kind of values am I looking for on the exciter coil and do I measure resistance (ohms) or voltage and over what wires? I believe this part is responsible for feeding the voltage to the CDI before being turned into spark by the pulsar coil (correct me if I'm wrong).
4)When checking the pulsar coil, what kind of voltage or resistance am I looking for and what wires?
5)How do I check the CDI, again what wires am I looking for what values when taking a measurement?
6)Are all of these components (minus the CDI) part of the stator? So I would remove the flywheel cover to find them?
Any input would be appreciated. I know I have the ability to fix this if you all could point me in the right direction. I've tried to narrow it down as much as possible by searching and doing my own legwork to give everyone a good idea as to whats going on with it. Thanks.
