- Minneapolis, Minnesota
New Torrent Ninja 159mm pump with Torrent driveshaft, torrent bearings assembled by Torrent, pump seal, and fittings.
Comes with Skat 159mm impeller fitted by Torrent Pumps.
SOLD
https://torrentpumps.net/product/ninja-pump/
Torrent Ninja is a total movement away from traditional pump design. In working with Hiroyuki Ogino “Hiro” for a year and a half we co-developed a new pump that adds low end hit, while retaining more water. This change from traditional pumps adds more top end as the pump remains charged longer after it leaves the waters surface.
Multiple changes have been made to the overall pump design. Vane leading and trailing angles have been completely changed with the Ninja Pumps. The lightweight Delrin tail cones have been completely revised for optimal water flow in the venturi portion of the pump.
The combined low end, as well as top end thrust gain has propelled our test skis for to a level unattainable by other pumps. Higher pump internal pressures with longer water retention provide more acceleration and greater height.
Riders like, Mark Gomez, Chris Anyzeski, and Niels Willems have excelled from using the latest technology Torrent and Hiro have created this past season. Now this superior technology is being released.
Lighter than the competition. The full stainless steel Ninja pump is the same weight as other “lightweight” two piece billet pumps. New construction techniques along with superior vane construction have allowed the Torrent Ninja PRO to be 25% lighter than the two piece lightweight versions offered by other manufacturers. Couple that with Torrents latest available offering of Titanium hardware, aluminum cooling fittings, specialty bearings, and you have the lightest set up available today.
The Torrent Ninja Bearings are totally redesigned for longevity and weight reduction. Our newest bearing is rated for 13,000 RPM unlike the 8,000 RPM of our competitors. This higher RPM allows for a greater safety factor in our products. Longer bearing life means more time on the water riding, not wrenching.
SOLD
