- Rexburg, ID
Chan hull, bb850 non pv. 148 pump 8/15 prop. Mikuni 46 dasa mani vforce reeds.
Water is pretty cold and with the 87 jet in the pipe I can still touch it.
But most annoying thing is it has a light switch power band just below planing speed. B pipe I could hold steady throttle and make my wake. I have to absolutely blip the throttle with the tnt. If I don't ski goes way to fast. If I have to little steady throttle it rides nose high and I tip over.
How do I bring the power band lower
Flow valve adjustments?, bigger pipe jet?
Also now that I am running dual cooling how do I restrict water flow to bring engine Temps up a bit?
Sent from my SAMSUNG-SM-G890A using Tapatalk
