- Horsetooth reservoir, CO
I did ping pong balls in my ski and it seems super solid. I laid up a seperate sheet of glass so I had a flat surface to stand on. I also reinforced the tray piece with some aluminum angle. It took 665 balls to do my ski. Don't forget to install drain plugs while it's apart. Here are some pics.
I laid everything up on a sheet of plexiglas so it turned out nice and flat (the plexiglas is not part of the tray. It's used for layup only) View attachment 211929
Then trim everything to fit. The black pieces have a layer of carbon on the top.
Add the aluminum. View attachment 211936
Then just lay it up. View attachment 211937
I'll have better guidelines on my build thread if I ever get around to updating it.
OK...this is really good to see. A couple questions. what size angle did you use and did you glass it to the bottom of your tray pieces? Also, what are you putting in the side walls for floatation? Any other pics you can share would be awesome. I did check out your build, and if you plan on putting them on there, I'll wait to see them at that time. Thanks.
