- Asheville, NC
So i've been able to get some hours on my ski and have it tuned in pretty well! I'm really loving the new pump the most, Its really night and day hook up from my old stock (and probably worn out) pump. One thing i'm having trouble with is after I fall off the ski doing whatever, It bogs a bit and will not rev out for 5 seconds or so and then jumps back up and hits. Weird thing is, this ski used to do the same thing last year before I rebuilt everything. I suspect this to be water inside the hull, splashing into the intake. I'm running my stock Yamaha intake because I believe it is the best at keeping water out of my engine, it is facing the correct direction and shouldn't be part of the issue. While diagnosing the water inside my hull issue, I ran the ski on the hose for a minute and I found 2 leaking clamps and tightened them. I also found that my new Blowsion hood seal doesn't really seal all that well, with the hood on I sprayed around the sealing surface and found that the front leaks horribly. Does anyone have a suggestion on how to get a better seal? Maybe a new seal totally or just add some wide weatherstripping to the new seal that's in there? Anyways I want to believe this is where the water is coming from and will hopefully fix my bog issue.
Problem #2 While riding with @Sanoman and @hornedogg79 I got my jetting pretty close and really dialed it in a few days later. I ran a new set of plugs last time I went out and looked at them today, They looked great. Mocha colored all the way down the electrode and slightly wet. I know this is not a proper plug chop test, but after running a tank of gas through the ski I wanted to see what the plugs looked like. My issue is that the ski still acts a bit sluggish and has a hesitation down low, very slight but noticeable when you're try to get some pop off a wake. Also the ski won't idle, it always loads up and stalls and won't start without blipping the throttle. Its also a pain to start when its cold, the primer makes it start but it won't stay running for a bit unless you keep it running with the throttle. I have tied the ski to a dock and followed the proper procedures for adjusted the idle, low speed adjustment and FCV. Everything seems to be set correctly and the ski runs well when you're riding but doesn't like to idle for long. I noticed today that when I got the ski idling on its own, i turned the hose on and when the water got to the engine it didn't want to idle and the engine vibrated like crazy. @Sanoman has seen a video of the crazy engine shake, you'd swear something was foo
ked. Just wanting to get some input for where I should go next on trying to track down these issues. I also started to tune in my B-pipe but i'll get into that later, crazy how much difference the screws make and which ones you open and close...
