New Build
Time to upgrade my trusty Ellsworth (2005).Went with carbon this time.
First step was get rid of the proprietary shock. The BikeYoke let me use standard shock.
RockShox Reba 27.5 150mm travel. SWAT Conceal Carry Tool/ChainBreaker. Takes place of starnut.
Chris King Bottom Bracket & Headset
Sourcing the correct parts for this integrated headset install was a 3 week ordeal. Not as simple as old school pressed cups.
Specialzed StumpJumper FSR Carbon
RockShox REBA 27.5 150mm Fork
XX1 Eagle 12spd Drivetrain
TRP Spykes Mech Disc Brakes
RaceFace Next R Cranks,Stem,Bars
27.5 wheels 150mm F/R Travel
What end is on your air station?
That is a sow cable cord grip with a .187 rubber gland, seals perfectly to the Presta. I can dump high pressure to seat bead, and switch to low pressure instantly to keep tire full for sealant to seal tire. Newer tires are better but old ones took awhile to seal, bead would fall off b4 sealant activated.
john zigler
Vendor Account
wisconsin
Nice build!!
I think I am going to switch my Trek superfly over to tubeless.
I have my Farley set up tubeless ( 2-sets of wheels/tires. Summer/dirt, and others are snow only) I just put a short piece of fuel line over the presta and pumped up with the air nozzle. My tires actually snap hard onto the bead though. I still like your hose end, and may make one up like this.
I don't know what you guys use for sealant, but I think it's all overpriced. Here's my sauce:
A nice humping teaspoon of mold builder (latex), 8 oz. of RV Antifreeze. @Flash-FX and I been doin this for years in various mixes. We used to add particles like ground rubber, or eraser, Flash even used glitter (explains those trees in the middle of the woods lookin like stripper poles). Throw it in the blender, put it in your tire, it seems to make it's own particles.
Nice build!!
Thanks! Tubing and clamp works great, always had to use a hose clamp and look for a screwdriver though, the cord grip makes it toolless .
