new b pipe... hmpf
got a new hull that has two water cooling lines coming in from the pump toe the engine compartment. my B pipe mani only has one entry barb on the bottom and i dont really feel like drilling and tapping another one. so heres the question what do i dooo to run duel cooling. thanks for any help. all the diagrams i found online have the mani with two barbs on the bottom to run two lines directly into the manifold
Waste Land
Non Multa Sed Multum
Florence, AL
Make sure you NEED the dual cooling before adding it. If I'm not mistaken it is possible to run a engine too cool and keeping it form reaching peak power.
yeah, good point, i usually have to run a resticter in at least one cyl outlet as the water temp goes down in the fall.
If you run pipe and engine on two different lines, you're not "dual-cooling" the engine, hence no need to worry about that. :biggthumpup:
so one into the mani... than on the head would i send two lines out? or plug one?
and one into the head pipe than out the top of the headpipe.. and to where? the stinger? or "T" to stinger and to pisser?
thanks
Frosty
New York Crew
Western New York
thanks
i run one to the manifold and have two go overboard from the head, however i also have both sides of the manifold connect to the one line in with a "T" so both cylinders get equal. (basically both sides of the mani are tapped).
yes, the one to the head pipe i have going overboard with a "T" to the stinger... i also run a flow control valve on the stinger line to cut back on water build up.
