Other new and need help thanks!!
JUST READ WHATS BOLD TO HELP ME OUT IF YOU DONT HAVE TIME TO READ THE WHOLE STORY THANKS!
so first time i rode anything was in 2006 in bermuda have no idea but it was sit down. and alot of fun so 2 or 3 weeks ago i picked up 87 550sx w/ race kit? idk and 89 650sx and 96 gtx w/ trailer all for $1500 all "run mint"... what a deal! and of coarse i tell the guy im into power sports been dirtbiking and 4 wheeling all my life and have a passion for anything with a motor (but im also no motor head but no how to hold a wrench and follow direction) so he's like well then dont start with this 550 to much power blah blah blah. little did he know they were all going out at the same time. so i put new batterys in all of them installed lanyard on 550 and new wires on the 650. all do run mint out of water and 650 and gtx run mint in water. 550 ran but had no top end speed but wasnt like choking. if i compared it to a dirtbike almost like it wouldnt go into powerban. so we rode for like 2 hours cause the guy said it had to be hot to run right well it never did. i gotta assume carb problems. then it died and now when you try and crank it over its almost like its a dead battery hardly cranking over but its not cause if it was dead or almost dead it would stop cranking over eventually but it keeps going. and it wont start. but thats cause at the same time it's cranking over so slowly im assuming theres no much spark. so i havent gotten into it much and idk what modifications have been done to it but i realy need a place to start looking im gonna bring my meter next time to figure out if the correct voltage is coming out of the battery cause if a plate breaks is it possible volt will drop? also we noticed that one of the wires is very corroded on the starter. havent had a chance to fix this yet but just wondering what other possibilities that it could be are thanks!!
i guess its pretty much all bold hah
Tyler Zane
Open Your Eyes
the corroded wire could be your only problem but then again nothing seems to be that easy. the only way to find out is try it and see. being that old it wouldnt hurt anything to replace it anyways.
i found a battery cable at a local auto parts store that work out pretty well on my 550. it was only like 10 bucks.
Yea im deffintly gonna replaced it reguardless hoping thats the only problem with slow cranking and then hopefully as far as it running maybe that just needs carbs cleaned
Tyler Zane
Open Your Eyes
very possible that its the carb. he said "race kit" so it may have an aftermarket carb, which would be to your advatage because the stock carb sucks... as soon as im done with my sj, thats the first thing im gonna do to my 550sx.
well like i said ive never had ones before so im learning and dont kno much the only thing that i have notiecd thats after market is the choke replaced with fuel primer. and a big as exhaust pipe. . . reminds me of the exahust on like a 2 stroke dirt bike or like a snowmobile
Tyler Zane
Open Your Eyes
man im no pro either, but i do know it came stock with a 38 mm keihin (91-95) unless its a 90-91 then it would be a 28mm mikuni (idk). if it was replaced theres a good chance its a 38 or 44 mm mikuni sbn (which have a square body). if you snap a couple pics of it with the flame arrestor off im sure someone can tell you what it is.
