- Rexburg, ID
I have an R&D water injection kit that came with my ski. after taking the motor out for a new top end I noticed the WI was not even hooked up to the dry pipe. Also the solenoid was corroded and full of sand. I have a few NX nitrous kits around so I'm guessing I can just use one of those fuel solenoids for the WI.
I have the box and Just need help with were the wires go. Im guessing in the box is an rpm switch and relay? so there is power, ground, trigger wire for the solenoid, and some kind of tach wire?
If I remember right the box I have is like this one..
http://www.maccracing.com/mm5/merch...uct_Code=RD-370-00001&Category_Code=RD-YM-WIK
If someone has the install instructions for the R&D dry pipe and WI install instructions that would be awesome!
