SterlingSilva
- Colorado Springs
ok well here are the specs...
750 w stock dual mikunis
factory pipe
k&n flame arrestors
carbs were recently rebuilt
75 low jet @ 1.5 turns out
147.5 high jet @ 1 turn out
needle is a 1.5 according to the stamp on the seat (stock?)
spring is either faded gold or dull silver (stock?) replaced with same when rebuilt
ski runs good... idles no prob... mid n top end good
low end is usually ok but occasionally get a bog/hesitation on the bottom end just off idle.
usually i feather the gas just to keep it alive n eventually it clears up.
thinkin im getting a lean condition caused by high pop-off due to the k&n f/a. i wanted to run the stock f/a to confirm this but it wont clear the factory pipe.
so my question is.... what is stock sxi dual mikuni spring and needle and if anybody can suggest anything id much appreciate it.
my plan is to try a spring one step lower and see what happens
the top spring is whats in the carbs now. the botom and middle are what came with the rebuild kit. i think top and bottom are the same
thanks
Eric
factory pipe
k&n flame arrestors
thanks
Eric
