w-nut
x2 nut
- christchurch new zealand
well ive kinda got a curly carb problem at the moment with my gp800. yes i know its a couch but it is a 66e and thats why id try in here.
the frist sytem off the problem was the ski was running fine one day and i left ot for a week or so and then came back to start it before a friend used it to take some pics off us in the surf and the motor was hydraulic with petrol. i cleared all the out and took it to the lake to see if it was going to run and it would only rev to 3000 rpm and was just pouring fuel in . at idel its fine but as soon as you give it any gas it wont rev over 3000 rpm
so i pulled the carbs and changed the needle and seats to a new ones thinking the needle and seets were stuffed. this fixed the problem for an hour or so but the problem has come back . so right now im thinking for some strange reason the diaphragm is holding the needle and seat open and its pouring raw fuel into the cylinders when you give it some gas .
do you think im on the right track or has someone experienced this before and has some ideas on how i can get this sorted .
im pretty convinced its carb problem and not elec as when this frist happened i was running a msd total loss ,and changed back to the factory elecs and it was still the same . im kinda at a loss right now
