Need Hose from Factory Pipe to FX-1 Water Box and other items?
I will need to buy the following items to install the Factory Pipe original FX-1 B-Pipe (the one with the water separator dimple) which I bought from Flash-FX * here.
Any suggestions where I can find these items?
1. The hose going from the Factory Pipe FX-1 pipe to the FX-1 oem water box
2. 3 Bolt headpipe gasket
3. 701 Yamaha manifold gasket
* @Flash-FX is a righteous guy. Along with the pipe, he included the head to pipe coupler, the coupler hose clamps, the high and low jets and adjustment specifications to install in my oem SBN44 carb, his original Factory Pipe installation instructions and the Warranty Card.
Just bought the gaskets from @SUPERJET-113.
BTW, he has a robust multi-use carb gasket which is helpful for re-jetting where you may have to remove the carb multiple times to get it tuned just right.
Still need the hose going from the Factory Pipe FX-1 pipe to the FX-1 oem water box.
Any ideas?
Kohldanielzimmer
Sierra Nevada Runoff Rider
Ahwahnee, CA
I have one I bought from JetManiac for a b pipe to a squarenose OEM waterbox. Id imagine diameter is the same but not 100%.
Sold my b pipe so I am not using it. Unopened
Diameter of the FX-1 Factory Pipe stinger is 2 inches. Not sure about the water box diameter. Not sure about the length or angle of bend yet.
FX1Dave / wavewarrior says just to cut my existing hose and, in fact, that is what the Factory Pipe instructions say to do. But I am a little bit of a weeny in this regard and would rather not cut a 27 year old likely irreplaceable oem hose if for a little money I can buy an aftermarket hose.
Daniel, any chance you could take some inside diameter measurements and some measurements?
I will pm Chris @JetManiac
