- thailand, bangkok
Hi guys,
i have 2010 SJ with B-pipe limited, TDR waterbox, i change main jet to 135, pilot is 70, spring is 95grams and the rest is stock. flame arrestor is stock.
currently the spark plug is number 7(stock). ( i live in bangkok, thailand) temprature around 32-35 degree celcius.
i follow the factory pipe screw adjust in pipe and carb.
pipe: open 3/4 on bottom screw, the rest is close.
carb: low 1 1/4, high 1 1/2 (front and rear)
i check the plugs after a few run and it is white.
i adjust the main to 1 3/4 (front and rear) and the plug is black only have on the plug.
i have ask around and they said the plugs is to hot (number 7) and recommend to change to number 8. the stock plug is 7 come with the ski.
I have adjust to find the best run on my ski which is Low 1/1/8 and High (F) 1 1/4, (R) 1 1/2. but the plug still white. i have open up both high to 1 3/4 up to 2 turn and the ski just blurble 1/4 up on the throttle then run but the ski very dull. and check the plug is black and dry. i try so many combination and the plug never got light brown.
Please help,,, appreciate your time
thank you.
dre
thank you.
dre
