- Edmonton, AB
I've been trying to get my squarenose back on the water, but I just can't get it to run right. I swapped motors a couple of weeks ago because my old 61x was worn out. The new motor 61x/62t came out of a running blaster.
The top end is brand new with some porting and it has a 5mm stroker. The only things that have change are the electronics, flywheel and pipe. It had a stock flywheel and computer, but I swapped it out with my 61x rad flywheel, 61x stator and msd enhancer. The pipe it had before was a blaster b-pipe, now it has a limited b pipe on it.
It idles fine a starts up easy, but when you hit the gas it completely bogs and wont rev up. I dont think the jetting would need to be that different because of the rad flywheel would it?
Any other ideas on what might be wrong?
The specs of the ski are
61x/62t some porting
5mm stroker
girdled head - 35cc domes
dual 46mm carbs
b-pipe
61x rad lightweight flywheel
msd enhancer
factory pipe water box
dual cooling
the jetting
130 main
115 pilot
2.5 needle and seat
95 gram spring
5mm stroker
dual 46mm carbs
b-pipe
msd enhancer
dual cooling
the jetting
130 main
115 pilot
2.5 needle and seat
95 gram spring
