- Midland, Ontario, Canada
Alright...I am ready to route my water lines and need clarification as to what I am doing. I am runnign a 99 Sj, single cooling, with b pipe and ada head. Now to my knowledge water should come in through the exhaust manifold, out the head into the bottom of the headpipe, out the top of the head pipe than to a tee which goes straigh to the stinger and other to the bypass/overboard.
Now my ada head has two outlets on it, should I block one off and only use the outlet at the very front of head or should I be teeing them together before going into bottom of headpipe??
Need to know if I am on the right page or completely out to lunch. Or if there is a better way of doing it?? Pls help! Thanks!
