- shark river nj
Ok, I got a new Factory waterbox after finding the baffles in my stock one had broken loose and were rattling around in there. I have never replaced one on a RN and whatever position I put it in always seems wrong. The Factory waterbox pretty much is the same shape but no baffles. It has one nozzle that is fairly straight and the other is on a good 45 degree bend. It seems the waterbox will go in to hull in two different directions depending on which way you put it. If you stand it on the tall side the 45 degree would be the exit side of the waterbox, and if you lay it flat, the 45 degree would be the intake side. Which way does the waterbox go in flat or tall, and which nozzle in the intake and which the exit. Thanks, Mike
