need 750 sxi big pin torque specs
bth
florida
anyone have the torque specs for the 750 sxi motor?
i am trying to reassemble a motor and forgot to have my local shop give them to me. anyone have a copy of the service manual specs?
gladly paypal you $10.00 for a clean emial copy in jpg or pdf this morning.
thanks
Waternut
Customizing addict
Macon, GA
PM me your email. I've got a copy of it. It's not the best pdf in the world as the "real world" pictures are pretty black but I've torn my engine/hull apart and it's had everything I've ever needed. No need to pay either...this used to be circulated quite a bit.
Waternut
Customizing addict
Macon, GA
Sorry I can't make it send. If you need a couple torque specs just let me know which ones. Otherwise do some searching. Maybe the manual is still posted online but not sure.
Waternut
Customizing addict
Macon, GA
Head bolts are 22 ft-lbs. Cylinder to case bolts are 25 ft-lbs. The 6mm case bolts go to 69 in-lbs (5.75 ft-lbs) and the 8mm bolts go to 22 ft-lbs. I think all of those have a specific tightening sequence to them as well.
