Super Jet Name These Reeds!
waxhead
wannabe backflipper
gold coast
vforce 3 look more like a kawasaki reed and dont bolt to the intake manifold like a normal reed block
They are sandwhiched between the intake manifold and the case. Make it hard when ytou decide to tunr a reed spacer as well. due to the intake length and the carbs hitting the exhaust rubber.
Thanks for the heads up chriselmore
D-Roc
I forgot!
V3's also snap together and you don't have to worry about them little screws that may look a bit stripped after the years of use. V3's come with different intake stuffers or whatever they are called. i didn't use my R@D spacer because of fitment. i could have made it work with a little tweaking but wasn't sure if 3's where to be used with a spacer or naturally space and angle with their desing, so i left it out.
